Nice pics, the 'trouble up north' and the side angle shots especially. Thanks for sharing.
I'd forgotten the pleasure of unpacking this monitor: open box, remove large piece of polystyrene and there it is, the panel in all its gloryCompared to the dell 2408: open box, remove large sheet of paper, remove little sheets of paper, remove cables, remove stand, remove little piece of polystyrene then big piece of polystyrene and eventually, the floor now covered in 'stuff', you get to the panel.
I'm still having a coupe of issues with this monitor and I'm just wondering whether you guys advise me to ask for a replacement or it's something that I can resolve myself.
The first is when waking the monitor after it has gone to sleep, firstly this seems to take an unusually long time. My last lcds woke almost immediately however the hp takes about 5-10 seconds to wake, then the image will flash on and off serveral times, sometimes just 2-3 times others up to 10. I've uploaded a video showing an example of my problem. The video demonstrates the response time of the monitor, at the beginning of the video I moved the mouse and it took approx 10seconds for the monitor to respond, at which point you can see that the image flickers on and off 4 times on this occassion.
http://www.youtube.com/watch?v=HXcmr014pkA
What do you guys think is there something I can do to fix this or is it some kind of problem with the input or something else that requires a replacement?
I think the second issue may be related but I'm not sure. I often notice that two frames seem to be merging whilst gaming with a visible split across the centre of the screen of 2 seperate frames. I know you can have issues with tearing when getting too many frames per second but I don't see how it can be an issue when playing crysis @ 1920x1200 and only getting 30fps or Grid and getting about 70fps. It's something I've never had a problem with on any past LCD so I'm not sure of its implications?
Any thoughts, these are still the two main problems I have with this monitor :S
As a note I have had the GPU longer than the monitor and it has never displayed any issues on my last LCD so I'm pretty sure the GPU isn't to blame.
@philjohn, I have set the hp not to search for inputs and for the default to be the dvi-1, initially believing the flicker may be from it attempting to read the other inputs for valid signals but this had no effect. As far as the tearing issues goes I was aware that it may be that but from the limited reading I thought it was only caused when the fps was greater than the refresh rate. I guess the best way to test it is to enable vsync!
I'm looking for a really good 24" monitor, primarily for PC gaming but also to watch blue-ray movies and connect a PS3 and/or Xbox360 "properly", displaying the correct 16:9 ratio (so small black borders top/bottom if full frame 16:9 on a 16:10 monitor) and at correct playback speed (24fps for blue-ray).
Can this monitor do all of this or is proper 1:1 pixel mapping necessary ?
(sorry if these are newb questions)
Ive played Crysis, Mass Effect (PC), Supreme Commander, Civ 4 and The Witcher on the monitor and it looks stunning.
360: Halo3, VF5, Ninja Gaiden2, DOA4 all look awesome as well at 1080p. Perfect 1:1 mapping over DVI (VGA via DVI for xbox360). Ive not tested HDMI as I still have a (working) launch day console. Just use the same RGB settings as you've calibrated for your PC and the colours should be fine.
Blu-ray: Die Hard 4, Pan's Labyrinth, In the Valley of Elah, Son of Rambo all look fine. No problems with HD Media.
The only thing I HAVE to mention is make sure you can live with a wide gamut display.
cman
Thanks cman, I have to say I'm a bit baffled by what the problem could be with a "wide gamut"...from the descriptions I've read doesn't a wide gamut just mean the monitor is capable of a larger colour spectrum ? if this is the case then surely the wider the better ? I don't really understand why it could be something I would need to be careful about so must be missing a point somewhere...
Glad to hear the monitor can play Blue-ray and console games in correct ratios though...this is definitely looking like the monitor for me![]()
what would someone have a problem with a wide gamut for?
so what is your opinion about it c0mdot?
Conclusion
Overall I was very impressed by the performance of the LP2475W. While default colour accuracy was pretty poor, once calibrated the screen offered the best colour results we have seen in our reviews. Black depth was excellent for an IPS matrix, and even out-did many PVA matrices we have tested! These were very positive improvements for IPS technology, and hopefully this is a sign of things to come. The screens massive range of ergonomic adjustments and interfaces was also nice to see, and the HP had a very "Dell feel" in terms of finish, functionality and features. Responsiveness was very good, but there was some slight RTC overshoot which caused some dark artefacts in practice. However, the decent pixel responsivenss, combined with pretty good input lag, could make this a good screen for gamers, as well as those wanting an excellent all round performer. If you want a 24" monitor, this is a hard one to beat in my opinion. Given the extreme lack of IPS in this sector, HP are probably on to a winner here.
