*** Far Cry 2 1680 x 1050 max settings Top List ***
24inch monitor needs less AA than a 22 ...but still...some AA should be needed. Disgusting jaggies.
Yeah i guess, i just loaded up my game, and turned the AA off, and you can notice small jaggies on the roofs of huts etc, but when you moving about its hard to tell, i have it set to 2x AA then its quiet hard to tell the difference when still and looking for jaggies. At the end of the day, id much rather have a sliky smooth framerate and a bit of jaggie and a below 30fps and no jaggies what so ever
+1
Run 1 is dx9 and Run 2 is dx10. Exact same settings. What's going on?
Here are the original result files:
http://dl-client.getdropbox.com/u/20407/23.10.2008 21.18.43.rar
Spec in Screenie and Sig
Not bad for my little 8800 GTX :)
I'll rerun the test now in DX10 :)
EDIT : DX10 result :
LOL
DX9
DX10
That's on a ATI 4870 (stock)
Q6600 3.15GHz
CAT 3.10 hotfix
8GB DDR2 @ 1:1
Vista64
Quads make a big difference in this game.
Q9650 @ 4.0Ghz
HD4850 Crossfire - 800/1150
E8600 @ 4.0Ghz
