Awww mate, im confused also...
Cant use my windows pc as its on the blink so OSX is all I can use.
Right Let me tell you what Ive done.
I put my iphone in itunes and let it update automatically (should I have done this?
Then I run quickpwn and let it do what it says.
But no joy.
So now im trying pwnagetool see if it gives me any joy...
I need it unlocking seeing as its on vodafone. Gutted about this...
Really need me phone to ring me mates - lost without it!
Gutted...
That's where your going wrong. You need to hard reset it to 2.1!
1. Switch the phone off.
2. Make sure iTunes 8 is open.
3. Hold down the home button and plug it in.
4. Make sure you keep holding down the home button.
5. iTunes will tell you it has found a phone in recovery mode.
6. Hit restore.
7. Will take about 10 minutes.
8. Run Quickpwn.
You can't update a Ziphone'd 1.1.4. You have to do a hard reset as outlined above. That is why iTunes is not recognising it I hope.
