How are you getting 9fps higher with lower clocked GPU without SLI and using an older driver? :/
Look at the CPU Speed and the FSB (=More Bandwidth) speed
Nobody on the DX10 table is using SLi mate.
It's not the CPU, I'm at 3.8GHz right now with higher bus and it makes no difference at all, plus i'm using a Q9550 which is faster clock for clock then your Q6600.
At what bus speed?
What drivers are you using?
What motherboard?
What memory speed?
Have you disabled any background services for crap like adobe, punkbuster, nero etc?
Defragged before running?
etc, etc, etc...
I could go on but I'm not going to do it for you
Are you accusing me of cheating BTW?![]()
lol, no I'm not accusing you of cheating, I just want to know where that extra 9fps is coming from.
I'm using a 180.43, the drivers that are ment to provide better performance, i'm running 8.5*450 (3825MHz) with rated FSB of 1800 and memory running at 1080MHz.
Have you tried the latast driver? it's ment to be faster and not slower which is what I don't understand here.
LOL
Just dropped back from the 180.43 driver because I was having problems running Bluray discs in arcsoft total media theatre.
Tried to see if there was a difference in the DX 9 tests and results were still around the 50-52 mark
Are you running your GFX card with the clocks linked?
I get simalar with DX9 at least, nope unlinked, i'll try linked..
Also my RAM is running unlinked at 1333MHz, yours is only at 1080MHZ![]()
I can't be bothered to check ALL the results, but the 4870X2 charts, despite posting a similar average score to the single GPU Nvidias, seem to be far less consistent and 'spiky', often with lower minimum frame rates. The closest 4870X2 score to mine whilst only being 5fps less on average, is 13fps lower at it's lowest point, and jumps up and down like a jack Russell terrier.
I know this isn't a resolution for cards like the X2 to even start stretching it's legs, so these discrepancies may be attributed to another part of the system?
