Ideas for new email address
Ok then, sounds a plan. Where is the best place to get a domain? Oooooh iam all excited, not sure why! :D Do you get anything extra if you spend more dollar?
Spend more dollar where? Depends if you want a .com or .co.uk?
As I say, I use www.123-reg.co.uk, do some searching on there for something you'd like. That's the first step, get the domain, then we can help with setting up Google Apps. Someone might be able to advise a better place for .coms though...
