Rapidshare
Status
Not open for further replies.
31 Mar 2007
How do you get around the:
You have reached the download limit for free-users. Would you like more?
Get your own premium account now! Instant download access! Or try again in about 15 minutes.
message?
you have to reset you router..
then reset your computer about 5 times to enable the flash cache to flush through the system and out through the interwebs tubes..
on mine i just pull out the cable, and put it back in, or log onto it and reset, always get a different IP address with my ISP
only if you've got a special service pack on vista then it does it for you otherwise 99% likely it won't work as the old cache is still in the system..
Just get a premium account, its only like £35 for a year or something, and you can download loads and loads. I use it a lot of TV shows in HD :D
Status
