ou need to restore your iPhone to factory first before you use QuickPwn.
Insert the sim from the provider you WISH to use first.
Clear down the folder where your iTunes restore files are Should be “C:\Documents and Settings\%username%\Application Data\Apple Computer\iTunes\iPhone Software Updates” (where %username% is your PC’s profile name)
Open iTunes with the iPhone connected and hold down the ‘home’ button. iTunes should recognise an iPone is connecting in ‘restore mode’. iTunes will now download and install the latest 2.1 firmware. Let it complete this but when it is finished do nothing more than close iTunes. DO NOT ACTIVATE THE PHONE just close iTunes.
Now run QuickPwn select the newly downloaded firmware that iTunes just installed from the folder above, click on and tick all the required boxes, choose the boot file paths and click on, go through all the steps and once the phone reboots you will be active with no prompt to activate!Happy Dayzz
The crutial part is the iPhone firmware must never have been activated via iTunes in the first place otherwise it will always fail when you change SIM cards.
Hope this helps ricardo.
Very nice iSam!
Must say, you were the person keeping me sane during my unlocking fiasco, so kudos to you young sir![]()
Want me to copy this into the sticky?
Done, links in the contents should work too. Also, can you still edit your posts in there?
Thanks mate, have a problem with Mike UK at the moment, so trying to smooth that out!
Do you mind if i add you to msn? could do with been talked through the basics
Cheers
Sorry, MSN won't work on the Mac on the uni network that I'm on. Email me, and I will guide you through it.
Cheers
Did mine late last night, worked perfectly
Thanks iSam
EDIT.... ok mabye not perfect, seems i can connect to my wifi but it wont use the internet and kate isnt working either????
Doing another quickpwn and ill see what happens
EDIT.... Still no good, got the wifi icon but cant connect to my router.... done various restores and nothing. Cant even do a factory restore to get my o2 sim activated as itunes gives me an error........ grrrr should have stayed 1.1.4 !!!!
EDIT.... OK too weird, get back from lunch and it decides it wants to start working????
Hey ya, yep still working (fingers crossed)
Just wish i could find another sms recieved tone as the stock ones are complete rubbish :/
The Uh Oh of my Kate install isnt working anymore
Im gunna miss the little dude !!
Thanks for the reply though iSam, i wouldnt be on 2.1 without your help thats for sure !
Indeed, what 02 sim is it? Not all work.
O2 3G Pay and go.
