Aekeron do you work for o2 broadband?
If so, where do you work? Leeds by anychance?
Am working in 2nd line support in leeds.
Any details most welcome. I wouldn't be surprised if at the very least I have to flash it (with the obvious danger that entails - I almost killed my old 2600 doing that).Bear in mind that your mileage may vary with the 2800VG. I seem to recall it's a bit...special on ADSL2+.
... i tried my other router today (linksys wag354g) and it seems to sync at much lower speeds so im stuck with o2 one for now.... is there a much better router out there for me to get higher speeds, or at least same as the o2 router but without all the restrictions
Are you saying it won't sync at all or it'll just stall at 8Mbps. As long as it connects, then while annoying, it wouldn't be the end of the world.I seem to remember you need the INP setting on your line set to 1, default is 2. Otherwise it won't sync above 7-8meg. I think only Be will change this for you, doubt O2 will. Fastpath may also do the same job as changing INP.
Even with all the correct settings you probably won't sync as high as you would with a modem with a Broadcom chip, e.g Netgear DG834GT
Is there anywhere I can get advice about this before attempting to jump ship?
Have they taken a DD payment yet?Got my router through yesterday, line's being activated on Thursday![]()
I was told they would 4 days< connection.
For about the last month or so I have been getting some poor ping times in the evening.
Normally I get about 25-40 to most CoD4 servers in the UK, then suddenly around 7-9pm the ping (on same servers) will go to 100-110.
Anyone know what could be causing this? It's not someone else on the network...and my download speeds seem fine. (1.3-1.6mb/sec)
Another problem.
Finding I can't play TF2.
Get the problem with your connection message with red writing in the corner.
Any ideas?
