- 2 Nov 2008
Hi,
I would like some advice on my new system please.
I have recently upgraded to the Phenom X4 processor running at 2.6Ghz on Stock Retail Cooling. My problem is that in games the screen freezes.
My CPU temp is 55-60 Degrees Celcius Idle! I get this figure from the bios at startup! Also to confirm SpeedFan, Everest Ultimate and 2 other small programs confirm the temp of 60 when Idle. Under load such as during games that must shoot up to over 70-80.
Is this normal? Im pretty sure its the reason for the screen freezing.
Could it be a faulty CPU or insufficient cooling? I dont understand because its the cooler that was supplied with the CPU so it should be cooling it to 30-40 when idle?
I hope someone can help me solve this problem.
My AMD 3500+ @2.2Ghz ran faster and smoother than this with no screen freezing in games!
My PC spec is:
http://www.overclockers.co.uk/showp...0 2.60GHz Black Edition (Socket AM2) - Retail
HD ATI 4670 1GB GFX Card
http://www.overclockers.co.uk/showp...770 (Socket AM2) PCI-Express DDR2 Motherboard
http://www.overclockers.co.uk/showp...0C6 1066MHz Dual Channel Kit (KHX8500AD2K2/4G)
650W Triple Fan ATX PSU
Thanks in advance for your advice and suggestions.
My PC spec is:
