Post Your Home Cine & HiFi Kit...
Kef Q1's
Cambridge Audio Azur 540a
Need to get some rubber pads for under the Q3's, really limited with what i can do with them at the moment with me being in uni halls :(
How are you finding this setup? I'm thinking of investing in something very similar but I'm unsure whether to get a NAD or CA amplifier (with either the DACMagic or Beresford DAC). Also, are they the Q1s or Q3s?
photoshop, how did you find the upgrade from the C315BEE to the C325BEE?
Kef Q1's
I had a weird moment where I had to look at you picture then look again, 'cos i thought you nicked my iTunes library! Arcade Fire :D
You going to put it the right way up?!? My bass has the speaker pointing to the floor?
that is the right way up! my velodyne points out rather than down also, a lot of subs are done like that.
gjc10212 - how have you found the room eq on the JL, thats one of the main reasons i would want it over the velodyne as the response in my room varies a lot.
New telly :) Specs as follows:
Toshiba 42XV555DB
Onkyo TX-SR705 receiver
NAD C352 stereo amp
Samsung BD-P1400 Bluray
Toshiba HD-EP35 HD-DVD
Pioneer DV-575 DVD
Squeezebox 3
V+ box
Monitor Audio Bronze B2 Main, centre and rear speakers
BK Monolith Sub
HTPC (Core2duo E6420, 2GB etc)
Hey bud, i have the 37" version of the Toshiba Regza and love it, how are you finding the 42?
Samsung 5 series 46"
Mission M74i fronts, M7C2 centre, M7DS rears (not shown)
Mordaunt-Short ms309 sub
Audiolab 8000a powering fronts
Marantz 4200 reciever powering centre/rears
All sourced from HTPC (including ffdshow upscaled live TV via media centre, makes a huge difference over the built in freeview)
Samsung LE37M86BD
Marantz sr5300 (purchased this in 2002)
Gale speakers
Sky+ HD
oppo-981hd
Harmony 555 Universal Remote
next on the list is a decent dvd upscaler, thinking Marantz dv6001 or a denon1940
Then a blu-ray player.
Then at some point I really need a new hdmi amp, But I would want to spend a bit of money on it and get all the sound decoding.
The upgrade was worth it. Sound is a lot better.
There is more bass and sound is a lot clearer. More noticeably clearer when turned higher than normal when watching a movie. I found the sound is a lot flat'er on the 315 but this is not the case with the 325. The 325 is ceratainly more atmospheric.
A very worth while upgrade!
[/QUOTE]
One word: OPPO !!!!
Forget the others and check out the oppo players E.g. the 980 ~£170, the avforums lads love them !
quite probably but they are expensive..
Also want a 360 to stream media from the pc and a wii for entertaining.. 3 consoles seems a bit over kill.
But a 360 is so much cheaper especially 2nd hand than a htpc.
Unless im mistaken, PS3s are still cheaper/comparable in price to dedicated players, and are the only BR players that can be guaranteed to be able to be updated if needed, along with other advantages?
Not sure now though, perhaps standalones have come along a bit...?
