- 19 Jan 2008
- Sunny Wales.
I should really of tried the free ones first but meh whats done is done.
Been offered an Iphone running 1.1.4 (Unlocked and Jailbroken)
Any idea if I can update this to 2.1 and then just jailbreak it?
What SIM would you be using? Either way, you can upgrade to 2.1. If it is an 02 SIM, then you won't need to unlock, only a jailbreak is needed. If you have any other SIM then you will need to unlock too.
This guide is great, but i've updated my 2G iPhone to 2.2 firmware and cant get iTunes to restore to 2.1 firmware.
So im stuck at the first step with iTunes restore
I'm trying to open Quickpwn and I'm already stuck as when I do I get this error:
I've tried redownloading and still get same error.
Help?![]()
Not yet, I was just confused as it won't even open at all. Or does it open as it detects the 2.2 firmware on the phone?
Ahh right cheers
I was running unlocked 2.1 on an orange SIM, so if I just update, don't activate and then run quickpwn I'll be alright then?
