I did do a little experiment though. I spread some AS5 on both the Cell and RSX chips in a thick coat, and then "etched" a criss cross pattern into it with a paper clip. I then mounted the heatsink on as tightly as I could and left it for a while. When I removed the heatsink I found that the criss cross pattern was still clearly present over most of the central area of the RSX chip. I.e. the heatspreader is probably concave and making crap contact![]()
Tendency of the wrist to move while lapping.why wouldnt it be flat if he uses a piece of glass?
lol nope, I'm back at my parents' place for Xmas, and still need to go out and get sandpaper etc. I take it 1000 grit upwards won't be easily available from B&Q etc?
Cheers,
Suman
I think Halfords do it.
No worries. Have a nice xmas.lol nope, I'm back at my parents' place for Xmas, and still need to go out and get sandpaper etc. I take it 1000 grit upwards won't be easily available from B&Q etc?
Cheers,
Suman
Starting out with the heatsinks; I've used the "razor test" and found out that my RSX heatsink is ridiculously concave, so I started lapping. Currently about half way through with the 240 grit sand paper and here's what it looks like:
Is that heatsink attached to something else? (the copper pipes in the picture, where do they go?).
...why dont you get a little hand held mirror that should be nice and flat and glue your sand paper to it?
why didn't I think of that?! Thanks dude!
well here are my results... only went up to 1200 grit so not super shiny (although I thought it would be at least slightly shiny?!). Much flatter than before:
