What the heck has that got to do with anything. It is a game you have to kill someone; white, black, Chinese, whoever. Are you saying only white people have to be killed in video games?killing Spanish or black people massive failure
I don't know if Code Veronica is considered one of the main storyline Resident Evils, but I found that to be one of the best ones in the series. I got it the day it came out on Dreamcast, and was blown away by the jump to 3d backgrounds. It helped that the graphics were really really good for the time too.
welcome back, not seen you post in a while
Apparently the PC version of Resident Evil 4 is a terrible port of the PS2 version. Low res / polygon character models, bad textures, no fog, no daylight, no darkness at night, so support for modern sound cards and effects, no shader effects, no mouse support... etc etc.
Is it really that bad? Have the mods fixed all this? I've never got into the Resident Evil series but would like to![]()
i disagree that they are long games.
RE - psx - 13hrs
re2 - psx - 10 hours
re3 - psx 10hours
recvx - ps2 - 10 hours
re4 - fantasic gamecube - 13hours
They are highly re playable though. I must have ran through each game at least 5 times.
The best ones are re2 > code veronica> 4> 3> one.
i would say the game takes that long if you know what you are doing, or at least a rough idea. with no hints or walkthrough the 2nd one took a lot longer than 10 hours i think.
Yep in my view its worse than the PS2 version, apart from being able to play in a higher resolution. The graphics have been touched up a bit with an official patch, but controls are still crap as there is no mouse support. Its still best played with a PS2 style pad or the Xbox 360 controller. Its just typical of console to PC ports. Just get the Wii version if you have that console since its the absolute best version of them all.
