glad you got it sorted mate, and glad you think you made the right choice
Just need to add the centre, rears and a sub now![]()
damn, been looking at subs and boy they are expensive!!
A descent one is around £250-400
The Denon AVR 1909 hasn't got very good reviews for the price bracket its in.
Certainly sub first. I have a 5.1 system and a 2.1 and the lack of centre speaker only makes a small difference in a small room. Adding the sub really adds much more to the sound imo.
I would personally go for the centre 1st, I find it makes a huge difference if you get a decent one. You don't realise just how much use a dedicated centre gets. it also locks the dialogue to the picture.
Sub is great don't get me wrong, but a centre is essential.
Yep, don't scrimp on the sub or all you will get is horrible OTT boom. quite a few nice ones around the £200 mark. Unless you have a big room I don't think you would need much more to be honest. I mean £400 would get you a BK monolith, a fantastic sub but is your room big enough.
what are you on about?![]()
How can you say a sub adds more than a centre speaker when the vast majority of voices are sent through the centre speaker? No matter what size the room is, the centre speaker is absolutely key in a movie setup!
Hi,
just upgraded my old pioneer receiver to the new sony 820.
i'm really impressed by it- It was a doddle to set up and the sound is really clear.
i have the ps3 connected via hdmi and will eventually connect up the dvd player etc as there's enough connections there for everything!
just my opinion but i dont think you'll be disappointed with the sony.
Personally i preferred a downward firing sub due to it being less directional and also less fussy about where you place it.
also consider the Quad L-ite sub in black http://www.quad-hifi.co.uk/model.php?sector_id=2&range_id=4&model_id=25#
Awesome sub that weighs 25 kgs with its own remote and is downward firing - can be had for £250 refurbished (although didnt see a refurbished black one)
Also not sure what reviews you read about the Denon 1909 - All reviews I read say its fantastic, just that the remote is a bit retardly set out (all configuration buttons on the bottom)
Had the 606 before the 1909 for 2 days as it developed the 'annoying buzz of death' bug thats plagues them and imho the 606 doesnt sound as good and look as good as the 1909 so Im well happy.
