- 28 Jan 2008
I would try starting from scratch. Save the game then go and replace those saves with your backups. Just to be sure they are in the right folders.
Although my eyes are hurting, i've been playing since 10, with only 2 food breaks in between :/Right lads, im confused here
Im on a mission called "One Last Thing"
You have two option. Which one should i go for lads? I need major help on this one. LOL.! I'm thinking of killing Dimitri.
But i wana know does the game continues or not, weather i take option 1 or option 2?
¬_¬
Yes i get the option for Deal & revenge. All i wana know is does the game continues after i done either Deal or Revenge?
someone please help me get my saved game backI've got my files but when I copy them into saved game it just starts from the first mission
Fixed it
You need to put this file in your GTA 4 Directory "xlive_wrapper"
¬_¬
Where do you get that file from? I would like to know how to solve this in case it happens to me in future and I am sure others would too.
Download the Xlive Wrapper from rick to play any downloaded savegame
Big Thanx to Rick
Download Link http://www.4shared.com/file/77104589/6d680157/xlive_wrapper_1207.html
I just tested it and it works no need to start from scratch again
Remember you need to have GTA IV 1.1 not 1.0
So you need to patch the game
Then this will work
STICKY!
ok, spec check time, Im pretty sure i wont really have any hope in running this smoothly at all (at decent settings), but here are my specs:
9800GTX 512mb
E6400 @ 3ghz
4gb of 6400 geil
1680x1050.
Worth a try or not?
9800GTX 512mb
E6400 @ 3ghz
4gb of 6400 geil
1680x1050.
Worth a try or not?
