Stupid question, will this let me do an upgrade install or does it have to be clean?
Cheers
-Leezer-
I belive it will update Vista 32/64 bit with SP1 but NOT XP
Cheers
-Leezer-
Cheers, not really important as its being stuffed on the laptop, but I'd rather upgrade as its less of a pain
-Leezer-
tbh i hate that taskbar style,
i unlocked it so it would like the normal one im used to:
January 2010 is the 'official' deadline, but MS are likely to RTM well before Christmas. There's a rumour they may even RTM alongside the Vista SP2 RTM sometime in April.Forgive my stupidity but is 7 marked down for a 2009 release? I've heard lots of good things regarding the performance.
Tried win7 32bit b7000 for a day:
*x-fi extreme gamer installed using vista compatibility
*dreamscene hack works but dodgy fonts on desktop & buggy
*wmp buggy/freezes
*wmc now supports hd codecs & ac3 5:1 but still not use actual folders in music library
*belkin wifi card wont install
*installing super-antivirus kills windows with an instant bsod & recurring bsods
*some virus monitors wont work
Still using Windows 7 64bit b6801:
*this build still uses old vista start-bar
*feels more like vista but I now have 4gig ram
Waiting for Windows 7 64bit build 7000...
Yep - use the option 'use small icons'.If there's a way to make the taskbar smaller then I look forward to having a bash at this one. I don't like my precious pixels being taken up by the taskbar
You won't get in to trouble... but it's public release is not far off anyway, so I would just wait.
Tis this build.A[L]C;13227065 said:Is it due to be a new release or will it be build 7000?
