How to lose the most weight in a single day?
Drink a bottle of milk of magnesia, get a colonic irrigation, run a marathon, spend 1 hour in a sauna, shave all your body hair off, pull your teeth and nails out. Job done.
You would be losing mass not weight.
Pies being angry, negative, and a thick Wiganer.
What do you think weight is, boy?
Assuming that you don't move to somewhere with a far higher mavity, removing mass removes weight.
Christ, you're a genius at times...
*n
Cut off my penis :p
Would be 1 stone lighter instantly :D
O wait : No knife :)
stand next to a really fat guy,and look at the difference :)
Cholera (after it's incubation period) - will probably loose you a few stone at least.
You might have the small problem of probably dieing within 24 hours though.
No-one has mentioned the other bodily fluid you can get rid of to lose a bit of weight. Rub one (or five) out, should tip the scales a little more.
Sex marathon...... i keep telling the missus it's the best way to loose weight and gain stamina!
I say the same thing to my Mrs but she just laughs and points out the fact that I'm 9 years older than her and sometimes struggle to keep up with her "normal" demands as it is!
:eek:
*n
wow, chill Winston.
