This is 2009 you know32bit version is a smaller download![]()
Quick question. Does anyone know if the key can be added at a later date after install? Pc is getting reformatted tonight anyway and will try this as primary OS instead, but will have to hold off until keys are released if they can only be used at install.
i fort you had 30 days to enter the key?
Argh!! 59% downloaded and it said something along the lines of "Cannot resume, the file has changed on the server or sizes are mismatched".
Why?
I dunno how the **** some of yous are expecting to run through a beta testing programme if you don't even have the patience to wait for a beta key.
The reason it's so slow is because of certain people that are only downloading it so that they can tell their mates on Monday morning that they've used the new Windows, and then spend the next few days telling us it's crap because it doesn't work perfectly for them.
If you're one of them then **** off and let those of us that are downloading it for the right reasons get our key.
