Daemon tools will not be compatible with a Beta OS. I have found Virtual Clone Drive works and its free! First time you reboot after install, you might have to manually power down, after that it seems fine.
http://www.slysoft.com/en/virtual-clonedrive.html
i had to dump win7, both x86 and x64 were giving me tdx.sys bsods when ever i connected to a samba share.
Where is the best place to download win 7?
Guys, when I browse 'Games' from the Start menu my system slows right down and eventually hangs? Games is the only folder in the menu that seems to do this, the others are fine
I'm running it in VMWare. Any ideas?
Have you told Microsoft?
# I Want My Quick Launch Toolbar Back! You might have noticed that the old faithful Quick Launch toolbar is not only disabled by default in Windows 7, it’s actually missing from the list of toolbars. As is probably obvious, the concept of having a set of pinned shortcut icons is now integrated directly into the new taskbar. Based on early user interface testing, we think that the vast majority of users out there (i.e. not the kind of folk who read this blog, with the exception of my mother) will be quite happy with the new model, but if you’re after the retro behavior, you’ll be pleased to know that the old shortcuts are all still there. To re-enable it, do the following:
* Right-click the taskbar, choose Toolbars / New Toolbar
* In the folder selection dialog, enter the following string and hit OK:
%userprofile%\AppData\Roaming\Microsoft\Internet Explorer\Quick Launch
* Turn off the “lock the taskbar” setting, and right-click on the divider. Make sure that “Show text” and “Show title” are disabled and the view is set to “small icons”.
* Use the dividers to rearrange the toolbar ordering to choice, and then lock the taskbar again.
Anyone else getting random crashes where the PC justs resets?
My PC resumed from standby and waked me up in the night too so I have to turn me PC off totally![]()
Ah... so it may have been this that meant my PC didnt shut off?
Just a quick question, does this install over the current install of windows?
esets beta. working fine for me. same for their AV
What's wrong with using the built-in firewall?
Kaspersky Internet Security 2009 working fine here too.
is that the prototype one they recently released, it asked me to register for that one didnt bother to see if it was free or not lol :S?
