- 24 Oct 2002
- Portsmouth
A 4870x2 burns only 79w at idle.
But that's cr@p though. A GTX 280 uses 25w at idle and frankly 79 at idle takes the mick. By it's very definition it's doing nothing and should be using far less!
ChillZ, 33w turned off?? It should be using about 3w max... Really I fail to understand why it uses any power at all when 'off'
is it true that LCD's use less power then an older 'chunky tv' even if the older tv is smaller in screen size???
EDIT: same question for monitors too??? TFT v CRT
Well I've updated my PC from a Geforce 8800GT to a GTX 280 and my power consumption has increased 40 watts at idle. This is very odd as every single review I have read has put them within 5 watts. It seems it could be an issue with the 180.x drivers.
I'm debating sending the 280 GTX back anyhow because in the games I play they don't really look any better despite all the extra graphics horsepower. I might just ride out this generation and wait for what the summer brings.
My housemate just got one of those meters that tells you power draw of your electrical devices.
My PC is as follows
Q6600 @ 3.5Gig. 1.41v
8Gb RAM
MSI P45 Neo2 Motherboard
Asus 8800GT gfx @ 700/2000
3x WD RE3 250Gb drives in RAID0
1x Samsung 1Tb drive
Creative XFi Fatality with drive bay
1x 200mm, 4x 120mm LED case fans
1x DVD-RW
Hiper 630w PSU (recent 85% efficient model)
And all of that draws...
167w at idle (with speedstep)
300w at full load, i.e. Prime95 on all cores
326w at full load, running Prime95 and in game Left4Dead at the same time!
you cant have it drawing 40w more than a 8800 and only using 25w at idle.. unless your 8800 has its own generator... that would be handy
That's good work Stonedofmoo, thats what I call finding the true VID kinda!My Q6600's default vid is 1.265v but I manged to undervolt mine to 1.025v and still be Prime95 stable.
All that idles at 136w. As you can see from my opening post thats down from 167w, a saving of 31w while still running my whole computer at it's stock speeds. I'm dead pleased with that![]()
That's a huge lump wattage, I discovered this myself a while back when I was building an overclocked Q6600 machine and plugged it into a wattage meter, real eye opener and was one of the main reasons I lost interest in high end overclocking . . . i.e there is no such thing as a free lunchAlso the difference between Prime95 @ 3.5Gig, 1.4v and Prime95 @ 2.4Gig, 1.025v is 110w!!
3.5Gig = 292w
2.4Gig = 181w
.... need to enable speedstep/eist
Clearly. I suggest you buy a meter that measures the power draw from the socket or you need to enable speedstep/eist
I've figured this out.
You're measuring what the PSU is pulling from the wall.
I'm measuring what my PSU is supplying to my PC.
Big difference.![]()
Quite. Our way with the Zalman is far more accurate as it's only the pc and not everything else.
only as far as what the components pull from the psu. it doesnt tell you what individual components pull and it doesnt tell you what the whole pc pulls either. Its far from idea and at least by sticking a meter between the wall socket and the pc you know what its actually taking/costing to power that pc.
The Zalman reads the power from the rear of the psu so it is total pc power consumption. You plug the psu power dongle into a socket in a sensor box. The box then has two leads coming out of it. One is the power lead that goes to the rear of the psu and the other is a lead that goes to the Zalman multifunction device and displays the power that the psu is drawing.
If you have a power monitor on the wall socket, unless all you have is the tower plugged in it will display the power consumption of the tower and whatever else is connected. The Zalman displays the pc's power consumption and nothing else.
Well then it does exactly what the power meter we has does. It measures one device at a time so clearly it's just going to show me what an individual device uses unless I attach a 4 way socket too it and power multiple devices through there.
Does it also show the results in kWh, volts, amps etc?
