Nah mate just gonna move it up so can slide rad underneath it.what order should it flow ? I'm thinkingYou wont notice it just do it whatever is easiest. I thought you had to remove the Hdd cage to get the rad in?
Rad-cpu-gpu-pump-res
You mean this one http://www.xs-pc.co.uk/rx240.phpMight be worth looking at the new xspc rx series rads.
would it be enough to cool the loop for cpu+gpu
That's the one. It's just out so hardly any reviews yet. The only one I've seen looked quite promising though.
My RX360 arrived yesterday so hopefully I can give you some better info soon, with regards to its performance.
Nice one Bradley, you and other peeps are legends for helping me out here...i'm quite excited to do my first waterbuildSwweet dude. You will also need a paperclip for jump starting your PSU and some Thermal paste (MX-2). you should have loads of coolent and tubing left over. Oh you want some nice sheers or something to cut the tubing nice and clean. Will be good to compare temps of CPU's once your up and running. Get some pics up of the build stages when ya can.
*Edit* you have fans?
My case lights are blue so would not mind some blue glow as gonna order windowed sidepannel for my case.
