Have to say i like the look of these builds but having someone else do it for me would feel strange.
How akward is it to run the atx connector under the mobo? I would have thought it would be harder to screw the mobo down because of that pressing against it, also is heat not a concern with the cable trapped under a motherboard that has hot areas?
Also how does mounting the ssd's work? Do they come with 3.5" rail adaptors or do those have to be bought seperately so they can be mounted in a regular hd bay?
Just had a blast of far cry 2, was a bit nervous about the challange this may hold. Anyway took the plunge put everything on ultra high, DX 10 and 8 x aa. Oh my god, it's faultless, doesn't even shudder. Cannot believe i own this machine.
is farcry2 a Dx10 game? if so, i didnt realise.. will have to buy it this weekend.
How much do you guys charge for a custom build? Looking to stick together an i7 rig as per: http://forums.overclockers.co.uk/showthread.php?t=17966449
farcry 2 is dx10 - it actually runs better in dx10 mode than in dx9 mode!
for a custom build it really depends on the complexity
you would be best calling through when you are ready to order [or know what you want] that way the sales team could help you spec it up
here is a nice one - SFF Crossfire Sugo
snip[/IMG]
It saves on central heating. Where's the OcUK Trademark MUG in the photo?
Does that not get a bit toasty in a shuttle case?
DFI P45 board
crossfire 4870 1GB
4gb dominator
intel q9550
