- 19 Oct 2002
- Shakespeare’s County
I'm a bit confuzzled as to how this will work with the Dell even with a VGA mate?
Yeah the red and white stereo leads go to the X1 red and white to 3.5mm female green jack. The male part of the phono leads doesnt need to connect to a TV, its just there for stereo pass through so you dont need to mess with wires when you decide to play with headset sound or TV sounds.
The X1's then plug into the green adaptor thats on the VGA cable from the Xbox, into the USB port aswell to power the amp on it, then the shorter lead plugs into the control box/amp about a foot down the lead from the headset and into the controller for the voice part.
The male part of those Y connectors doesnt need to go to anything.
