Grand Theft Auto 4
I'm currently playing all my games at 1680*1050 on a 22" monitor, so I should be okay then?
I think it's time to re-order ;)
Be fine at that res, if my system can run it half decently im sure yours can :p
Just don't expect to be able to throw all the settings up.
You can also get the fps to show using xfire btw.
Saves installing fraps :p
Just press scroll lock & x with xfire on, and then pin the FPS display (there is a small pin shaped icon you click)
...btw.. I ask again heh, is MRK using DX10? as his game looks almost real :eek:
Maybe cos the pics were high res but he shrunk them to a much smaller size, making them look higher quality? Dunno :)
Anyone had the game freeze for about 3 seconds, then crash (GTA IV has stopped responding etc) ? Im not sure yet but i think its related to having Clip Capture on :/
Not impressed by the new patch. I get slightly poorer performance. And still get slow down after about 10-15 mins. More RAM needed? Faster CPU?
My game won't run :mad:
I tried the patch and still no good. It comes up in task manager for a couple of minutes, and then just disappears. The game doesn't visibly launch at all.
Patch broke it for me, been playing on and off for weeks without issues, patched tonight and i get not enough video memory errors randomly and crashed to desktop, havent changed any settings, just patched, might try the nvidia drivers
You need to tinker with the settings, i think if you leave it alone after the patch is isntalled the quality settings are actually higher.
EDIT: To the posters above, is this a STEAM install? Have you verified the files etc?
What O/S?
I re-installed the other day, and theres a fair bit to do to make the game playable O/S wise.
XP / Vista? If it's XP you need SP3 and .net 3.0 I believe, and the latest flash somewhat or other....latest live...games for windows...quite a bit :p
Nope its from the dvd and as i said its been working fine till tonight when i patched it, I even played this morning until i found the patch was out, have installed the new drivers although I was running the betas anyway, no time to check now......
Play around with the game setting anyway, as theres a few more settings you can tinker with now.
Funny. I dropped all the settings down to low except the shadows. Kept my res at 1680 x 1050 and it runs the best ever (surprise surprise). Only 380mb VRAM being used. But the quality still looks great! Odd!
My logitech rumblepad 2 worked fine with the 1.01 patch.
The 1.02 patch claimed to add support for the logitech rumblepad 2.
My rumblepad 2 no longer works. The patch has actually done the opposite of what it was supposed to. Great.
Just an update to the 2nd patch for me, I have to say it’s amazing now, the graphics seem to be improved a bit too especially at dawn/dusk and even though I mentioned I didn’t see it drop below 30fps yesterday I have seen it drop below to the 20s this morning BUT the thing is now when it does drop to below 30fps it does not feel like it’s running below 30 at all, still feels like above 30fps, very hard to explain but it’s similar to Crysis Warhead where anything 20fps+ is smooth.
I guess it’s the new vsync and rendering optimisations the patch adds that helps. I upped the GFX settings some more too and saw no difference in performance. Shadows selectable options are all on highest settings now.
Overall I very much enjoy this more now because of these optimisations.
