- 3 Nov 2004
- UK
Post a screen shot of the cmd box with your commands, maybe I can see something wrong.
Can't get this to show me anything
I'm a cmd prompt noob though..
Can anyone see the error in my ways?
G:\Program Files\RivaTuner v2.22 is where rivatuner is installed to
Its written on it.
Plenty of 4870 getting results. Non-reference design seems to have issues. Different controller, probably the cooler phase design.
I don't know, does it have the standard looking cooler? The vast majority are reference.So i need to take the card of the mobo then, i've got Sapphire ones, so is that non reference?
Open the cmd prompt
G:
cd\
cd\Program Files\RivaTuner v2.22
RivaTuner.exe /ri0,70,1A
RivaTuner.exe /ri1,70,1A
RivaTuner.exe /ri2,70,1A
RivaTuner.exe /ri3,70,1A
That's up to you, 90C wont kill it though, as they're designed for high temps. Personally I'd not want to see temps that high for long.question ?
when useing these voltmod ect up to 1.3v ect as long as i keep the temps under 90c should be fine right ?
115c is the thermal throttle right ? so should be fine correct ?
It means you have the plugin yeah. Check on the monitor page under setup and see if the gpu voltage option is enabled, you may have to scroll down the monitoring page to see it.Here's mine, not showing under monitoring but when i checked under setup --> plugin, it's already ticked and also this one, is this mean that i have vt1103?
I personaly am getting sick and sick of not seeing a better cooler coming out for the 4870X2 series cards..
ATI are always the bottom of the foodchain compaired to nvidia. Im getting sick of it.
