the 1100 will not include blutooth either.
The 1000 does do sky hd.
Just as well I'm not interested in Bluetooth
Does it do Blueray?
Does it do Blueray?
Oh dear Photoshop, it seems somebody has put a mirror down in front of your tv so you now get a terrible reflection.![]()
Sorry Photoshop it's just that the pictures with the reflections off your coffee table reminded me of when i used to have a glass topped coffee table and i used to be able to see the reflection when i was sitting on my couch watching tv. Needless to say that coffee table was thrown out after a couple of weeks.
finished building my speaker amp (normally a headphone man).
And yes, that is a sex in the city boxset, and no, its not mine!
and the headphone setup....
Thanks for the kind words
Your right. That is not the original default skin for MediaPortal. The skin im using is called Monochrome.
I've modified mine a little by changing the backdrop and removing the icons![]()
I get 12 watts per channel, it does a damn fine job with me KEF Q5's. However, they are now the weak link and will be the next item replaced.
It doesnt get too hot, each valve is only dissapating 11.7 watts on the plate, and about 2 5 watts from the heaters.
Sounds stunning, so much better than my old solid state.
It's not really about watts so much as ampage. A watt is not always a watt so to speak (well it is, but bear with me), using high quality components but having a lower maximum total output can and does yield much better results, an amp with only a 20w maximum power output could well be able to supply the same or even higher current than a cheap amp rated at 75w or so. There is much more to it, beyond the obvious numbers that people throw around.
I know more about transistor amps than I do valve, but the same principle will hold true. Valve amps can be quite deceptive. While it is true, that it is not the best idea to put difficult high current loving speaker loads onto lower powered valve amps, you would be surprised by what a fairly modest valve unit can do with a typical speaker load.
For instance what happens when you double the load to a 4ohm load, and amp X at 20w per channel into 8ohms has the current to double it's power output to 40w into a 4ohm load. But amp Y at 40w in 8ohm lacks sufficient current to double to 80w into 4ohm, which is what would be needed to essentially maintain the same level of 'volume' ... and has to cut that down to say 60w into 4ohm.
