- 17 May 2004
Whats the state of multiplayer like on the PC. On the xbox it was really really poor, all servers had the same settings, autoaim on, nametags and dots on map always on. It was a case of chase the dot and then hold down autoaim and fire.
I think that autoaim for the PC should always be off, and that dots should not show up on short range, that way you wont get to seperated but you will have to tread carefully and acctually aim, use cover etc when hunting someone down.
Should be picking it up tomorrow if that morrisons offer is still on.
Thats what I usually have my settings at if I'm in charge.
Is it not possible to custom map controls to a joypad?
