I just tried my Netgear router
down up
Connection Speed 9356 kbps 1203 kbps
Line Attenuation 44 db 12 db
Noise Margin 6 db 5 db
Not as good.
I am going to try that tonight ^^
After reading a few things they dont like to actually disable interleaving and put you on fathpath but just limit the effect of interleaving to a minimum.
It should be better - are you using an old firmware?
By livechat do you mean calling them or do O2 actually have some kind of live support I can use on their website?
http://www.samknows.com/broadband/search.php Put your Posty in there mate and it will give you the info.
I think Colindale and Edgware exchanges got LLU presence from a lot of operators I saw O2 in there as well. Still a bit hit n miss even with the LLU stated speeds sometimes but a lot better than BT.
But both exchanges showing WBC enabled at the back end of last year!
Broadband Connection > DSL Connection >Details
Yes it can be hard to find.
Link Information
Uptime: 0 days, 0:16:17
DSL Type: G.992.3 annex A
Bandwidth (Up/Down) [kbps/kbps]: 459 / 244
Data Transferred (Sent/Received) [kB/kB]: 0.00 / 0.00
Output Power (Up/Down) [dBm]: 12.0 / 14.0
Line Attenuation (Up/Down) [dB]: 47.0 / 64.5
SN Margin (Up/Down) [dB]: 5.5 / 6.5
Vendor ID (Local/Remote): TMMB / BDCM
Loss of Framing (Local/Remote): 0 / 0
Loss of Signal (Local/Remote): 0 / 0
Loss of Power (Local/Remote): 0 / 0
Loss of Link (Remote): 0
Error Seconds (Local/Remote): 0 / 0
FEC Errors (Up/Down): 0 / 1,891
CRC Errors (Up/Down): 0 / 1
HEC Errors (Up/Down): 477 / 1
That's pretty grim, LLU or Access?
You can bookmark the page then go straight to it.
not looking good, does the sync speed auto adjust or do i have to keep rebooting the router to see if i can sync higher?LLUnot looking good, does the sync speed auto adjust or do i have to keep rebooting the router to see if i can sync higher?
ive read in the DLM stage i shouldnt touch the router for a while,
