i hope all the "oh not dont do that" isnt putting him off from updating...
TBH it is annoying as the laminate is a compromise I had to do to win the space.
I know the drawbacks of solid flooring quite well thanks to all who commented.With furniture in and a big rug it will be fine trust me.
Anyway moving swiftly on, I ran into a few problems.The electrician put his back out causing me this delay.
I did't want to post a pic of one wall painted and leave the thread again until its completed, hence the delay in posting.
So my next update will be when the Floor is finished and the plugs fitted and lights. This week hopefully.
I'm getting Sky HD installed on Tuesday and I have to power the TV etc.. when he comes off an extension lead.
Running into problems like this, on a project like this, was bound to happen.
Plus side is all the painting is finished and 50% of the floor is down. The finishing around the window is done too.
Its going to be a really nice space I think. I have 8 more electrical sockets (4 are done) to get fitted then the wall lights and then I'm clear to bring in the gear.
If you want partial teaser pics then just say but its so close to completion in Decorating and wiring terms I thought I would give you the finshed empty room.
Then take pics of the gear installation.
P.S don't ask me for Pics right now....Its snowing and with no light or power I don't want to go arse over tip!!!!!!!
