i've just got back from shopping. now i'm ready to test it.![]()
Bought mine (spec in sig) and it's awesome. Although, having come from a socket 939 system, anything is going to be faster than that but I'm damn well pleased.
Money well spent as far as I'm concerned.
64bit uses more of the cpu. its always been the case with amd cpu. my old phemon 9850 can run at 2.9ghz with stock volts on 32bit of xp/vista. but on 64bit vista it can only get to 2.7ghz with stock volts..Probably OCZ Freeze, I haven't heard about a O/S being 32/64 affecting an overclock how so? Got a link for me to have a read?
i will look for some links after i've set this up.
How much did it cost you roughly to upgrade then? Motherboard/RAM/CPU wise I mean...
As I might do it one day (funds pending) as im still on my X2 4400![]()
I keep getting tempted to grab a Phenom II 940 and a new board.
I have no need for one, as i'm on a Q6600 at the mo, but I just keep getting tempted back to AMD, if only to 'have a play'.
hehe...Wrong! after you have set it up & overclocked it.
AMD OverDrive stabilty test and prime95 and afew rounds of CINEBENCH R10 64bit..What are you using to test stabilty?
But looking good so far![]()
vista 64bit i use as main os..Which O/S do you use as your main one?
Either way providing you have the cooling shoould be plenty left with a bump of voltage![]()
lol. i don't know whats cpu vddc... i thought cpu vid is vcore on amd chips..How strangelol
I put together an upgrade using a Phenom II 940 BE on a DFI UT 790FX M2R this morning, so far I am very pleased with it, and I haven't overclocked it yet, I'm going to run it in for a few days first, I always like to do that with new CPU's. Right now I am using the stock HSF but I do have an Noctua N12 on my C2D which I will switch over in a few days, when I am certain everything is ok.
I upgraded from an C2D E6600 at 3ghz. As you might imagine, at stock 3Ghz it isn't widly faster than the C2D where the extra cores are not needed, but for the type of multi tasking I do the system is much smoother and outright faster over all.
I play a lot of Supreme Commander, which does utilise more than 2 cores and that is much better, that is probably the area I have noticed the biggest differance so far today, it's very smooth indeed and stays smooth as the game progresses, unlike the C2D which would be ok, perfectly playable, but not totally smooth, and zooming in while much was going on would cause stutter on my C2D, not so on the Phenom II.
Temperature is ok, it's idling at 40c right now, but as I said, I am only using the stock HSF and I just used the ready applied thermal compound. My case isn't the greatest in terms of cooling though, I built it more with being quiet in mind, I use a Coolermaster Cosmos 1000 with 4 120mm Sharkoon Silent Eagle 1000 fans in. When I put the Noctua on using some fresh MX2 thermal compound in a few days, I expect to see temperatures drop dramatically, then I will try some overclocking after the thermal compound has cured, so another day or so I reckon.
Oh incidentally, I am using Windows 7 Beta 7000 at the moment. One problem I did find is that the latest official Bios for my DFI, that allows it to support the Phenom II, disables the onboard LAN (both of them) under Vista 64 and Windows 7 64. I already knew it did under Vista but I did not know that it would under W7 as-well. Fortunately I have a few old NIC's lying around, it's running fine with a Realtek nic right now, hopefully they fix this little issue with the next bios release.
To be honest though, for an official bios that is a bad mistake, it should not have been officially released with such an error in it, fortunately I knew about it before hand and was prepared to deal with it. That will not be true of everyone though.
