hubba hubba, I want that red head.. sexy as hell.
She’ll give you more than cancer.
As I was saying Trans-Fat. It can be used for a month rather than a few days with normal olive oil.
Any store manager caught using their oil for that long would get sacked or the franchise revoked in the UK. Maximum of a week, less in a busy store.
You see these kind of messages all around California - they seem quite strict on it!
What store is that? McDonalds? Do you know for a fact what type of oil the store you are refering to uses?
I read that information on the length of oil life from here or a link on trans-fats directly (rather than the subset name used to disguise trans-fat presents on some labels):
http://www.westonaprice.org/knowyourfats/mono_diglycerides.html
They use a blend of vegetable and rapeseed oil in the UK (it's something different in the US, or at least it used to be), but the real reason I posted was the idea that it would be acceptable for a McDonalds store to not change it's oil for a month, it's not. Daily filtering, weekly change is SOP, rising to twice daily and bi-weekly in the really busy stores/periods.
http://www.mcdonalds.co.uk/ourfood/potatoes/page8.html
Yeah but doesn't that fit what I was saying? If you use natural oil in McDonalds then you would change it every few days, whereas if it was trans-fat oil (which is pre-heated was designed to make candles originally) then it would be much longer up to a month.
However even if they use natural oil, I read that any oil heated to extreme will basically be bad too.
Whenever I go to McDonalds I only order a Big Mac and Double CheeseBurger, no fries so it shouldn't effect me. Although I do get a cod n chips Fridays.
Thats what got me a bit confused, in that even if they use natural oil, then does it turn bad when its used as intended and heated up to cook the food?
Trans-fats are banned in sweden and at the same time this got banned heart disease dropped like 40%. You will probably die of heart disease before I will but I just don't see a reason to eat unhealthy stuff knowingly. Plus its got to help with lifting heavy weights.
fake
Yup, there was a massive scare when I was a kid about eating burnt toast. Bit pathetic if you ask me when a few years earlier they were banging on about how charcoal was so good for various stomach complaints like wind.burnt food can cause cancer :S?
That sounds like a distinct case of correlation not equaling causation. Heart disease is a long term issue, so if the ban and the drop coincided, the drop had nothing to do with the ban....
The super size me documentary has killed my love for them anyway.
