That's pretty good power draw considering you got a mama Radeon sitting in there!
However the fact that it's your "Games Rig" really does justify getting the memory frequency running faster?
You have a Radeon HD4870 which tells me you crave FPS so I don't understand why you would slow your gaming performance down with slow system memory?
Tom's running his sticks at little over 1.8vDimm @ 540Mhz so it just shows how good modern sticks can run with a little tweakage!![]()
Well, from what I've seen from My testing running the CPU at 4ghz and the memory 1:1 gives a nice balance 1Meg super pi is 11.4 sec and gaming at 1920x1200 cranking the system up to 4.2/4.3 ghz does not give any worthwhile gains and certainly less than 2 GFX cards in crossfire...but they have gone as I can't be doing with the Heat/noise and power just to play a couple of games a few frames faster (and the ones that needed the boost did not work well with crossfire anyway)
I've had plenty of Systems that Hung on the edge and after a couple of hours online gaming the mouse/usb controler would cook and go intermittent or something else would "throw a rod" ! So My take on extreme overclocking now is Start with a proper watercooled ground up setup like Gurusan or be happy with a mild stable overclock
Whilst I've had fun in the past getting up early to a cold PC and seeing it could hang together long enough to break 15K in 3dmark before everything got hot
I think I get my kicks out of making the hole rig run as cool and quiet and low power as possible and still have high end performance when I need itBut please if You get any big memory related gains on Your new build keep us all posted....because I know your pretty methodical and sensible ( took You 2 bloody weeks to try that bios I sent You for a 4850...) LOL could be intresting
