- 12 Sep 2008
i think its the Biostar thats making it possible - its a great motherboard.
I've managed to push my 920 to 3.5Ghz 100% stable without having to change anything in the BIOS at all but the FSB. All volts are on auto and I only have the intel stock cooler (albeit I do have some mx2 paste under it). I'm very pleased! The temps are about 31 at idle, i havent measured it at load yet but it must still be quite low because I am on stock volts..
Don't forget the bios will scale voltages with baseclock. Auto settings should be monitored, don't just assume all is well.i havent measured it at load yet but it must still be quite low because I am on stock volts..
Dont know why your messing about with tiny increments and hours with Prime 95.
Just get LinX and run it after an overclock. If your unstable you will know about it within the first 10 minutes.
Most i7s start getting into problems around 3.7 ghz - 4.0ghz with vcore the most likely problem.
When HT is on, LinX only achieves 50% load and does not tax the CPU anywhere near as much as Prime95 on blend of OCCT.
Aye that it is, but auto doesn't necessarily mean it's at stock. Check what it is on that hardware monitor thing after it posts.
Linx does if you set the number of threads to 8. You need the newer version of it.
ok I now have 3.57Ghz stable on 1.328 volts which isnt too bad at all. Whats the max the DRAM voltage should be again?
