I think you should tell the competitor that you have tried it in 2 of your freinds computers and it does the same thing, and as a customer you want a replacment. Tell them, dont ask you will be supprised at what you can do.
The CONSUMER is the king!...
Not if they prove its working.
. Of the two unless your having other problems on the system as well i would say it is most likely the card. I don't have a spare pci-e card laying around at the minute so can't help but maybe worth buying a real cheap crappy £30 thing to test if the mobo has problems.
