What Coolant is that; I'm looking for a really deep red coolant.
Feser One UV Red is blood red, but looks carpy orange when under UV, which is a shame.
Sipha, this may be a stupid question but how do you plug in your DVI lead and sound leads when your res is that close to the back of your case?
It's looking really nice though.
You sure you've got the right size coils for your tube OD there mate? I don't think there should be any gap between the coil and the tube. Either you stretched them when putting them on or you've got the wrong size. Might not be a problem in this case as the tube bends seem to look ok, but I would say with the gap, the coils probably aren't actually doing much to prevent tube flattening. Is it 3/8" ID tube your using? You can get both 1/2" OD (mainly Feser) and 5/8" OD tube, and coils to suit. I know cos I bought some 5/8" ID coils by mistake and they were very slack on my feser tubing, although mega easy to slip on, rather than wrapping like you normally have to do. I didn't use them though.
Bump with a few updates of mine also:
Can i ask you where you got that side panel from?![]()
From OcUK actually mate, think it was £21 or thereabouts
Just found it: http://www.overclockers.co.uk/showproduct.php?prodid=CA-064-LL&groupid=701&catid=209&subcat=1295
I actually ordered this style but got the 1 you see, I didnt mind tho as it provides some extra cooling and looks ok too.
You could try and ring them up direct mate, I see they only have 1 remaining instock they may be able to check it for you ?
Tbh with you, if it does turn out to be the plain all perspex 1 and you wanted the 1 with the side grille I would be willing to do a swap if you liked as I'd probably prefer the plain anyway. Email me if your interested.
....but wheres the RAD???? it looks great but i cant help thinking theres something missing![]()
Heres mine, my first build aswell(not quite finished still),
Let me tell you it will never be finished! My first build still isnt finished and that was a few years ago now lol
Looks good though, like the green in that case, everyone seems to use blue with your case.
, yeah im keeping to just blue leds and then green piping and cable management.Hi Matt, if you looking for nice blood red coolant I have one in my MM thread:
http://forums.overclockers.co.uk/showthread.php?t=17977386
