Man of Honour
- 21 Nov 2004
I have mine all sitting at 300Mhz in 2D mode to keep them cool.
Actually, what have you set the RAM to?
Can anyone tell me why in crossfire mode my screen flickers/pulses single card is fine no flicker?
This is in a game only; I have tried v-sync on and off 9.1 and 9.2 drivers.
It’s only in darker scenes that you can see this.
If some of you users who are now crashing with 9.2 while on the same GPU overclock then you should know better that you should test without the gfx OC to see if the crashing stops.
If it does then its your gfx overclock at fault & not the drivers.
I very much suspect that users have OC the gfx card to the brink of crashing before 9.2.
Any possible increase in performance will bring an increase in heat (may need more cooling to be stable now with your Overclock) & strain on the GPU (may need more Vcore to be stable with your Overclock) or both as its doing more work than before in any particular game & may now be being pushed over the limited with the previous Overclock & may need bringing down a notch.
...Crysis is the most overated game to ever grace the PC. I can't believe ATI are still bringing out new drivers thinking we are all still playing it...
Albert
i get what your're saying Final8y, but the drivers should normally improve performance through code efficiencies and normally dont result in any greater GPU load - therefore keeping the heat the same
