anyone use winamp 5.5 lite?
5 Jun 2005
Southampton
used to love winamp back in the old times when it was a great if not the best mp3 player!
just downloading and giving the lite classic a go, anyone still use it or rate it?
Erm it's still the same as before...just with a more modern skin.
Not that I recall....I update when updates are out and install it only and nothing else.
well when it was winamp 1 and 2 it was great and i used that old version until i moved to Vista last year. if i recall winamp when **** up on version 3 doubling in size and system usage
Love winamp, use the newer bento skin, it's fantastic imo.
Use it for all my music needs, I love the library compared to everything else out there, I hate wmp/itunes etc as you don't have separate artist/album/track sections.
Fast. sounds good, looks good, I recommend :)
Yep v3 was terrible. v5 is good though again :)
i use winamp lite, agent off etc..
with this skin i made
http://bleddyn.co.uk/creations/LR_Royale_Black.wsz
i edited another skin to make mine
Using the latest version here, but only to play music which it does fine. Job's a sorted.
There's not been an update in a while though. Same with VLC..:confused:
yeah i just use it for single mp3 use, forced to use itunes having 3 ipods to manage and keep my data clean and to be honest use wmp11 for avi playback
You can use iPods with Winamp? I remember having mine and having to download a seperate plugin (it might even be integrated now), and being able to interact with it flawlessly through the media library window.
When a mate's iPod got plugged in - Winamp just recognised it as a different device and away I went. :)
