-i see so with my own upgraded hd in the ps3 i do a back up then reformat and default factory settings then take out.
-then put in original ps3 hd
)-i see so with my own upgraded hd in the ps3 i do a back up then reformat and default factory settings then take out.
do a back up - THEN REPLACE THE ORIGINAL DRIVE - then reformat and factory settings
other wise you are wiping your larger drive clean
But restoring wipes the ps3 harddrive anyway to make space for the backup data i thought? Even if it doesn't he'd end up with loads of duplicate data when he restored files he already has on the PS3 back to the PS3 if you see what i mean.
Streeteh whats this about 1 of the 5 DLC/PSN credits? I didnt do that and I already formatted. Is it a bad thing if I havent deactivated my PSN as you say?
Did they ask how long you owned your PS3? I bought mine 2nd hand about a year ago and it doesn't read discs anymore now.
They did and they asked me to fax the receipt to them.
Streeteh did they do that to you? Tbh my conversation with them was quite heated. The muptard on the phone kept telling me that it could be a hard drive problem and it needs to be formatted and that will solve the problem.
Anyway bygones.
The PS3 maybe registered on EU playstation page, ask the original owner if possible if not try yourself may help a bit.
Tbh Im well hacked with the Sony guy. Its the first time I have been asked for the receipt (I previously returned a PSP after 4 months with no questions about receipt) which is fair enough, but make me feel like a liar. Furthermore, he said they will only repair it and not replace it.
Strange tbh, for me they just asked for the serial number and 'approximately, when did you buy it?'
How long ago was this?
By the way, I formatted the PS3 but my login details are still there. Is there a hard reset that needs to be done in addition to the format?
I had my problems about 4/5 months ago. I guess the recession losses Sony have seen have made em tighten their belts.
