Just installed my two Sammys and its flying, really really brilliant difference!
Ive ran the SSD Tweaker.
However, when I tick both the boxes in the HD section (enable write cache....) the boxes dont stay ticked.
Anyone know why it might be?
Where abouts are you trying to enable the write cache? In vista its in the device manager in the properties of your volume.
I believe you can do it from Intel Matrix Storage Console too. If your using an Intel chipset mobo.
I dont use the intel software, but yes im trying to enable it in the device manager.
I tick both boxes -> Apply -> ok.
Back into DM and the devices are unticked.
Thought id post another benchcy
I really don't trust hdtune, I did a bench last night and it was showing similar results. 400mb/sec sustained with burst speed of 1200mb/sec. I'll stick with Atto tbh seems more realistic.
There is a buf / FW issue where read speeds are twice the rated when there is no data in that area
if your board uses intel chipset tho, get the latest intel matrix storage drivers.
is that hdtune you meant, i'm not completely convinced, I'm actually not sure but isn't Vel running 4 of the 64gb's, if all in raid those numbers look ok, the early numbers look like crap though.
Its dodgey but I can't tell which way, atto gives me 200mb's read, hdtune gives me around 100 for that first small section then 200-220mb/s for the rest which is about what you'd expect.
Its hard to know whats accurate though.
Thing is its hard to know, are the only people getting more than the drives rated speed getting it from bad benchies, like the samsung review showing 160mb's read.
Its still not a bad drive, and perhaps my results are limited by running off normal drives with os not on the faster ssd's while I'm testing them.
Still can't find the perfect setup, theres not a "huge" amount of difference with any of them tbh, though my sequential and random read in crystal mark seem 5-10% higher with a 128kb stripe and a 128 offset, 256 offset isn't much worse but a little, and 512 hasn't made much difference at all from 256.
Looks like i'm gonna use 128/128, or 128/256.
I've had XP installed on my samsung i tried to install Vista on it but i'm getting an error on the select a drive screen.
"unable to find a system volume that meets its criteria for installation"
I tried setting the SSD to active in disk management, tried formatting etc but the problem wont go away. Can anyone suggest why this is happening?
Sorry i wasn't very clear in my post, its late and i'm frustrated with my pc.
I am attempting a clean install. It is just refusing to install to my SSD, i suspect something to do with allignment is causing it, but i thought Vista sorted all that out?
I can't image re-image my old OS back on to the drive now either, as its saying the Drive doesn't match the size of the image :S
how do u use atto nothing happens comes up with, cant open fill bench,can anyone help please
