problem has evolved....
it now wont start. turns over fine but the car wont actually start :/
AA on their way![]()
. Good luck with getting it sorted - shouldn't be too expensive.The reason I'm not so sure its LPP is because you would have had a fair amount of diesel in the tank making the LPPs job almost pointless especially once moving. It would have been much more likely to die with 1/4 to half (or less) in the tank.
Hope you get it sorted anyway.
interesting, it has just over 1/4 of a tank now.
but then i only drove it 4 miles from work, it started at work, wont start out at home (started twice at work iirc).
Ok, well you can hear the pump and it is is getting something up (took the pipe off the filter and a little diesel was coming through).
Unable to get anything from the diagnostics, the AA stuff has nothing for diesels at all! Generic connection pickup up nothing.
Lucero - are you saying that putting say £20 of diesel in (which would put it back up to about 2/3rds), might temporarily sort the issue? (of course i would then need to keep it topped up)?
Going to have a look now for an Indy in north london - anyone have any recommendations? (though I can have the car towed wherever).
i can get AA to tow it anywhere, so it might as well goto a garage tbh, as thats where its gonna end up anyway!
I was going to suggest taking it to Promotive off junction 28, but as you are already going to Bristol...
