silversurfer said:
How does it look now with the gel removed?
I was looking through the pics I took yesterday and it looks like I didn't take any after scraping the gel off, which is annoying because I was sure sure I had.
I found a pic in my folders of some treated metal I did a few months ago though which was similarly corroded:
Stonedofmoo said:
Awesome thread, I've really enjoyed going through it. Keep up the pics with your progress.
By the way what size is the engine and what sort of power did it put out when it was new?
1.8 and when new it had something like a mighty 90bhp when new
To be fair to it, it's a light car and at speeds of up to 60 or 70 feels urgent enough when the second choke opens.
Above that though it really starts to lose puff so I'd like to put something bigger in when I get the chance. At the moment it will do though
Didn't get as much done as I wanted yesterday but made some progress still.
Firstly, primed and stonechipped the rear end panel behind the bumper:
Then topcoated, lacquered and refitted my bumper. Looking out for a straight replacement as mine is the wrong colour and it's warped at some point.
Got the floor nearly done on one side before I ran out of MIG wire. I'm not a great welder but I've tested it with a lump hammer and pry bar and it's well attached. Needs lots more grinding down as gasless welding doesn't half make a bloody mess! When I'm happy with the welds I'll paint this area.
Also finished off the rear arch with some stonechip and then a coat of underseal. I'll dig out the arch spat today and refit:
Finally, tested the lights.
Sidelights:
Dipped:
Main Beam:
I've checked through the MOT manual and can't see anything illegal about having 4 sidelights. Not sure what UK lighting regs say but if I do get any bother it's easy enough to disconnect the inner ones.
