To close ?
EDIT: Not sure which the secondary slot is as they appear to be different on the Deluxe rev. 1 and rev. 2.
Re: the fans, could give 'em a try, although I'm not sure the airflow would be very good. Be a man and break out the dremel! Cut some holes!! :D
What can i use to cut the holes out then ?
Dremel or a holesaw. Depends if you want to go to all the effort though. I'd also worry about possibly compromising the structural integrity of the case.
So you think it be wast of time doing it ? or just add the fans with out the holes ? i need to make my mind up. just want them 2 card to be cool
Why not just try it without doing all this extra effort and see if you really need it... run it and keep watching the temps, if they stay stable and everything works then hunky-dory but if it gets hot then do all this..
I don't see any big problems with it tbh.
As a lot of people have said, as long as it doesn't block any vents it's fine.
EDIT:
Probably.
If you decide to put the two 120mm's at the bottom, it would help immensely to raise these up off the bottom of the case, even if only by 2-3mm if this is possible.
Something like some rubber washers or rings for the fans to sit on to absorb vibration..
EDIT- 100 posts btw!!!!
http://www.overclockers.co.uk/showproduct.php?prodid=CM-003-LL&groupid=701&catid=209&subcat=
Thats if the temps become an issue
I've got one fitted to my PC-P80B,i opened mine up & turned the fans the other way so they are blowing into the case.
And yes the fans are very quiet.
Do they come as sucking air then ?
Do you have yours blowing onto the card ?
And how far away ? got any pics ;) is yours that colour.. looks nice. :D
It's comes with the fans exhausting hot air out of the case but it seems to work better with the fans sucking air in to the case(it's only a 5 minute job to swap them the other around).I got the silver version as it's matches the cases internals.
I'll get some pictures posted up later this morning.
