any fix to creative drivers recently ?
having to use my onboard instead of my Audigy 4 Pro as I only get about 5 mins of audio with the A4 before it just conks out
onboard is perfect
onboard is perfect
yup certainly am
games play fine for about 5-10mins then no sound
did a search and seems lots of people have the same problem
you on 64 bit or 32 bit version please ? 64 bit in my case
Each time my PC goes to sleep, it disables my wifi connection. Is it possible to stop this happening?
Try going into your device manager and unchecking the "shut down to save power when this device isn't in use" or similar.
After a few days I'm really liking the new task bar. just goes to show try new things of ra few days before you decide to remove it.
I had to select never combine taskbar buttons
I'm sure it's been posted in here already. But is there away to get windows7 taskbar more like vista. with separate quick launch and open tabs.
