- 15 May 2006
Anyone any ideas why my system isnt overclocking as per bios? Windows 7, doesnt seem to know what the bios is set at!!!
Just about to install W7 to a RAID 0 array using the intel chip on my Gigabyte P35C-DS3R and this is making me think twice (about RAID 0 not W7). What hardware are you running?
tried it, formatted, back to ubuntu... will be a while before i do that again
My isn't My documents in my user folder?
where's yours?I gotta say for the most part I'm liking it so far
Which Anti Virus/Fireware are you guys using in 7?
A notepad file opens every time I boot into Windows, is there a way of stopping this?
Fix Windows 7 Build 7057 Notepad Auto Open Desktop.ini on Startup Bug
1. Open Windows Explorer, then click on Organize -> Folder and Search Options.
2. Go to View tab.
3. Under “Hidden files and folders” tree, select Show hidden files, folders and drives.
4. Uncheck Hide protected operating system files in order to be able to view the hidden desktop.ini file.
5. Click OK when done.
6. Navigate to C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup folder, or alternatively, just type shell:common startup in Start Search and hit Enter.
7. Delete desktop.ini file inside the folder.
8. Navigate to C:\Users\USERNAME\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup folder, or alternatively, just type shell:startup in Start Search and hit Enter.
9. Delete desktop.ini file inside the folder.
10. The bug has been fixed, and no Notepad window with desktop.ini will appear on reboot or startup anymore.
