What's the best way to make money that people have found?
I am on my 4th run now doing pro for first time. I just pick up money on the way.
- Running through chapter 5-3 and ending the fight with XXXXXX early, this nets you around 60K per run ... but takes a little bit more time!
I understand that if you fully upgrade a weapon you can get unlimited ammo for it, is that right?
Can I use that weapon with unlimited ammo with a new game playing on Veteran or Pro?
Any hints for this? I'm really wailing on him, but he never seems to give up.![]()
Yep, once you fully upgrade a gun you can purchase the unlimited ammo from it through the bonuses (using the points you gain for completing stages).
Then you can on unlimited ammo when you start playing.
I've not tried but I'm fairly sure you can use unlimited ammo anywhere. Can someone confirm?
That's what I've been doing mostly.But I'm running out of Magnum ammo too quickly and having to resort to weaker weapons.
I think I'll leave this for the moment and go play mercenaries until I can afford the points to get infinite Magnum ammo.
Thanks.![]()
I was looking at Gamefaqs at a big discussion what the best place was and it's either 3-1 for ease as you can get a few thousand without spending ammo and the other option is 5-1 or 5-2 but this requires ammo, a good gun and access to chapter 5 but the rewards are much higher.if u need money just farm chapter 3-1 takes 2 mins and gives u 6k
Is there anyway to move tehse weapons to the inventory screen mid levels or do I have to sell them ?
I am only at 2-2 so I guess I will see what 3-1 is all about, is it only the beginning, quit, save and do 3-1 again?
