Man of Honour
- 15 Mar 2004
- Liverpool
The best of luck!
Where is newcastle under lyne is that Newcastle as in the city or what? I knew I should have paid more attention in GCSE Geography!
Nope. Newcastle-Under-Lyme is near Wales. Newcastle (Newcastle-Upon-Tyne) is in the North East.
I'm going to have to cycle down sometime from Manchester to buy some hardware![]()
with bigger offices does this mean you'll be stocking more products ?
MW
I hope so because I could not get an enterprise edition hard drive recently from OC; the Hitachi Deskstar E7K1000 (E for Enterprise). I will look again at my options as OC is always striving to improve for the customers benefit and we should continue our support. Good luck on the move![]()
can we see some more photos of the building, inside too. How much bigger is the till section going to be? Will there be more systems and popular components on display for us to look at and/or test. It's always nice to see high end keyboard etc in the flesh before we buy which is why the DSG group is great for us who want to check out what new printers, keyboards, monitors etc look like before we buy.
btw, you really need to change your process of reviews for your products, i've left quite a few reviews, they take forever for you to approve them. What you should do is allow them to be added without approval and have a "report comment" button so that if there is a comment that isn't allowing like swearing, racism etc then your staff can delete it.
Maybe you could give us some details of where the nearest train station is and how far it is walking distance from it or near bus stops and things.
You should add some cheaper brands of bluray BD25 discs and dvd+r dl discs, Aone can be pretty decent and are very cheap at competitors, same with ritek.
You should add more core i7 bundles and add the asus p6t v2, your biggest competitors sells that board, you dontthat, core i7 920 and http://www.overclockers.co.uk/showproduct.php?prodid=MY-152-OC&tool=3 would be a very tasty bundle.
maybe you could add prices in 2's for harddrives to encourage people to get 2 for raid0, eg 500gb seagate 7200.12 might be £49.50, add a price for £97.49 for 2, you'd sell a lot more. You'd be able to use your larger warehouse more effectively buy ordered in larger bulk and getting them slightly cheaper.
also add a "report invalid specification" button as lots of your products have mistakes in the specs eg the liyama 2009 model on here: http://www.overclockers.co.uk/productlist.php?groupid=17&catid=510
it says 10,000:1 contrast but its 20,000:1 contrast, if you click on it you will see the specs in the detailed view are correct but not in the overview specs, there are loads of products with similar mistakes.
