DIY bods in here - redundant light switch
thanks to you lot pauls looking a bit confused.
No. No he isn't. He knew what everybody was talking about, you're the one trying to confuse the issue.
how would he know its just an empty box?
If i asked for ...
and got ...
i'd notice the difference pretty quickly. Wouldn't you?
( |-| |2 ][ $;13731259 said:
I'd be more interested in working out where the wires go... Is it an immersion heater? Isolator for the garage or loft. Why removed it, a switch looks better than a blank plate? Unless you do it properly and recessed and then plaster over it.
Ok, well here's the switch
Here's where the wires come up
And it seems to be connected into this thing (any ideas what it is? Old ceiling light?)
the white thing is a jb (junction box) does the same job as a CHOC BOX.
Good grief, stay away from electrical fittings.
That is a ceiling rose, there is usually a a piece of flex coming out of the hole in the top. It does look like an existing light fitting has been removeed but the cabling left in place.
Also, where is the switch actually located in the house?
It's the hallway of my basement flat, I don't think it's a junction box, that picture is overexposed and doesn't show the hole in the middle of it. You can however see the dimple where the hole is in the second picture
I think it is an old ceiling light thing where you can dangle the wire through the middle, it looks the same as some of the live ceiling light things (sorry don't know what they're actually called)
your right serves me right for not actualy looking at it properly.
Yeah after reading SB118's reply, and re-looking, it isn't a juction box. The flash hides the hole.
So I'm guessing the lights have been replaced with their own switches?
