Caporegime
- 20 Oct 2002
- Wish i was in a Ramen Shop Counter
So gaggia baby to descale, Joe Glow for external bits.
Anyone seen the presso machines?
http://www.singleservecoffee.com/archives/012875.php
Might be a solution for me at work where I can't plug anything in.
If you open a bad don't put them back in the fridge or the condensation causes quick deterioration.Ok so I have a problem with my Baby Gaggia:
The plastic end on the steamer keeps popping off under the pressure of the steam... extremely annoying.
Why does this happen and what can I do about it?
Ta
Anyway, I have a few questions...
1) Following Siliconslave's guide on how to make an espresso my machine takes an age to pour anything out of the portafilter, the only way to get a steady 25-sec shot is to not pack the coffee very tight at all - pretty much just use the weight of the tamper (it's a wooden/metal tamper, not the rubbish that comes with the machine so it's a fair weight). Is this normal? I really don't want this one to be faulty too![]()
2) Cleaning. Can you back-flush the Gaggia Espresso Pure? It didn't come with a blanking disc so I don't want to give it a try and break the machine - the manual doesn't help on this matter either.
3) Milk frothing/heating. It takes ages to get the milk up to temperature from cold, the froth comes up nice and quick but the milk stays cold unless I steam it for about 60-80 sec. Is this just me being a newbie and using fridge temperature milk?
4) The coffee comes out faster from the left hand portafilter spout (not sure what this is actually called...) compared to the right one, resulting in one espresso being finished before the other - is there a way to combat this?
