simply go to the ROM page, download the ROM, extract the package. Within the package, should be a wrapper (this app will take you through the whole process). in the case of Duttys, its called BlackstoneRUUWrapper (think this is the norm).
ensure your HD is visible in windows under activesync (or mobile center etc for vista). ensure its not seen as a portable drive, only activesync.
then literally once its recognised and you have over half battery life, load up the blackstoneRUUwrapper.exe. itll guide you through the rest.
fairly simple. as for backing up, im not sure, i never bother![]()
Need to flash with HSPL first
