How do you get the bit behind the icons? The theme of the actual rocket dock and not the icons?
Linky?
Linky?
Star Trekin Across the Universe...
http://img216.imageshack.us/img216/2831/trekin.jpg[IMG]
Only goin forward cos we can't find reverse...
[URL="http://forums.overclockers.co.uk/showpost.php?p=13611955&postcount=101"]http://forums.overclockers.co.uk/showpost.php?p=13611955&postcount=101[/URL][/QUOTE]
Why does that blue deflector array thang look like a painted metal dustbin lid, is that from the film?
Objectdock v Rocketdock .Which is best? I'm not using either at the moment and was wondering if there was much difference. Both made by the same company, Stardock?
Both pretty much the same tbh, with objectdock you can add a start menu button if you want, which I don't believe you can do with rocketdock. But I use rocketdock because I don't like having names above the icons when I hover over them. You can remove the labels with objectdock too but you cannot when it comes to stacksdocklets, so no brainer for me, rocketdock.
They can both use .pngs icons, same backgrounds, have zoom effects etc.
I thought you could turn off the tags in the stacks global settings tab?
Id look but ive not got any docks atm![]()
) what they were.
A change after so long!
I am literally way too picky on desktop wallpapers, virtually only a handful of walls take my fancy
http://robbiekhan.co.uk/root/mrk/desktops/desktop_crush.jpg[img][/url][/QUOTE]
Thats one well organised start menu. :eek::cool:
And that image is huge :rolleyes:
The forum resizes them..
